wisser rubber vervangen
Geplaatst: wo 14 okt, 2009 23:38
op verzoek van Ronald
als er iemand zich geroepen voelt om het mooi te vertalen .
en eventueel de origine text te verwijderen (weet niet hoe het zit in verband van texten van andere forums af te halen en te delen
(mod's)
"new" wipers at 2 euros
In fact there are not new wipers but rebuilt ones.
Yesterday I have the good luck to go into a Norauto store, where in the "specials" secction they have 2 rear wipers from a Clio II, 300mm (12")long, at 1 euro each.
This DIY can be done with extruded rubber profile type wipers (continuous section). The cheap type from norauto or carrefour are not valid.
My wipers was from Valeo and the donors too, and the seccion for the rubber are the same.
Is worth to say that this wipers are rebuilt one time before, but using this profile buy in an auto-parts store, but be carefull because this material can be stored at the shop for years.
How to:
The new wiper model and cost:
Comparative between 2cv wipers and donors:
To loosen the rubber you must press it with a plier, to loosen the inox reinforcements.
The inox reinforcements have a shape to fit to the wiper estructure, just press it and force to slide it along their axis:
checked that the rubber profiles are the same:
Slide the rubber profile and inox reinforcement into the wiper structure.
Here you can see the new profile assembled, there are 5cm excess to cut, because the 2cv wipers are 250mm long.:
Cut the rest, and the new wipers are done:
How to:
